Home> Productos> Conmutadores> Access Switches>
RG-S2952G-E V3
52-Port Gigabit L2+ Managed Switch
Ver más+
NFPP Network Protection
RG-SNC Topology Management
Design For Durability
RG-S2928G-E V3
RG-S2952G-E V3
24 10/100/1000BASE-T ports
4 1G SFP ports (non-combo)
48 10/100/1000BASE-T ports
Fan Slots
Fixed
Management Ports
Up to 256Gbps
Up to 96Mpps
Up to 132Mpps
Up to 16K
Routing Entries
IP Host Entries
(IPv4/IPv6)
Up to 1,500
AP, LACP, Flow balance
Up to 128
Layer 3 Features
Layer 3 Protocols (IPv4)
Static routing, RIPng, OSPFv3
RAS
(W x D x H) (mm)
440 × 260 × 43.6
≤3.5kg
≤4kg
482560 hours
372690 hours
Lightning Protection
6KV
Frequency: 50 to 60Hz
≤24W
≤40W
Storage humidity: 5% to 95%RH
IEC 60950-1,EN60950-1
Emission Standards
RG-S2928G-E V3
RG-S2952G-E V3
PoC Guide
Release Note
